seimans 7 400 PLC and GE Proficy change management software
bm1971
Oct 2012
dysart
I m installing GE Proficy Change Management Software at site. We use GE Fanuc PLC's on firld equipment.
But the process plant is changing to Seimans 7 400 PLC's running on PCS 7 V7.1 software.
Is this compatible with the Proficy Change Management software to allow a single point for version control and access.
I know the PCS 7 has this ability but we would like asingle point of control using GE Proficy Manager.
Secondly if it is not compatible does anyone know of a program that would be compatible for both GE Fanuc PLC and Siemans Ucsing PCS 7 software so I can have one point for version control and access amongst other things.
I am confused, the guru's from GE are telling me that it (Seimans PCS 7) isn't supported with Proficy Change Management. His response below.
What are your thoughts.
Thanks barry
Hi Barry,
I have looked through the IPI for the latest version of PCM and we do not currently support PCS (any version) we only support S5/S7 and some CNC stuff:
Project Type Modules
Siemens S7: Versions 5.3x and 5.4 SP1 and 5.4 SP4.
As-is Project Type Modules
The following project types have not been validated for the Proficy Change Management 5.9 and 6.5 products, and are available as is:
Siemens S5: Version 7.2.
Siemens 840D CNC: Siemens 840D CNC ARC files from the archiving system in the CNC PCU (PC Unit).
Depending on the required functionality, the PCS project types could be added as a custom project type.
I can give you a call on Monday to discuss if you’d like?
Regards,
I'm confused too, the documented in the link references Siemens S7. Maybe I answered the wrong question. If GEIP gave you an answer why do you expect a better one from the general public?
they hadn't replied before the original posting to my question
GE Proficy does support Step 7 but when it is running on PCS 7 software it doesn;t support it, apparently. I don't understand why.
I didn't have a respnse from GE when I posted the original question. there response came through after I had the reply.
Thanks for the help.
Does any know of a Change Management software program that is compatible with both types of PLC's below. It needs to be able to do automatic...
3,491
i have a problem with a program loaded with an eprom that i believe is not correct. the machine beside it has an identical program and i can...
2,035
I am fairly new to programming and have an old seimans sytem SMP-E423-A30 CPU and cant find any documentation on the seimans site. Problem is I...
1,270
Just getting started testing the new S71200 ladder logic is basic but have not found any good analog sample programs for the 2 channel analog...
1,701
Seimans Step 7 Question I am going to be interviewed for an electrical maintenance job, It's for conveyors,using Seimans Step 7. Does this...
3,082
