Proficy Machine Edition Software Training
View of Status: input, output ONLINE - Proficy Machine Edition
Hi friends:
I appreciate you indicate me: which option I should enable to view ONLINE the change of status in the ladder (input contact, output, etc.) , I'm using: Proficy Machine Edition Software - version 6.5.
ONLINE I can see the changing status using the tool: DATA WATCH.
I'm attaching two images: One of them of my application "online" and the another an image I found on the internet of a process that I want to monitor ONLINE.
Thanks for your answer.
To view the Status of your Contact you need to Be Equal with the controller. Your program and configuration in Proficy must match that of the controller. Look at the status Bar at the very bottom you see a blue diamond with an X on it. Blue is you are in moniter mode and the X means your logic and or Configuration are not equal. You can see which one by the Logic NE in the status bar at the bottom. Go into programmer mode be Clicking the green hand by the go on line either download your application to the controller or upload application into your machine edition. Whatever your choice Remember to save the original in the controller so you can revert back. I recommend Uploading from controller and doing a Save As renaming. Then you can revert back if something does not go quite right. I recommend Proficy Machine Edition Getting started Guide. GFK-1918
I'm getting frustrated creating arrays of variables in Machine edition. I need to make 2 variable arrays that are 102x2 in size, with varying...
105
Hi, I am still a beginner with PLCs and I have never worked with GE PLCs before so looking for some help. I am using GE Proficy Machine Edition...
1,378
I am trying to download version 9.8 of G.E.'s proficy machine edition, does anyone have a link to a download site?
5,152
Need to learn a few more tricks in Proficy Machine Edition. I don't use it often, but one of the first things I usually do when getting into a new...
1,022
I have a GEFanuc plc 90-30 that has dumped it's program and IP. The tool in PAC for setting a temporary IP is not available. The Offline Commands...
2,023
