Proficy Machine Edition "Set Temoprary IP Address" not available
GlennM
Aug 2006
Motor City
27
I have a GEFanuc plc 90-30 that has dumped it's program and IP. The tool in PAC for setting a temporary IP is not available. The Offline Commands says (none). I have tried using the mac address via CMD using ARP and Telnet to no avail. Any suggestions? I need to get this up and running!
The temporary IP address tool in Proficy only works for the Rx series PLCs. It doesn't work with the 90-30. All 90-30s are accessible using serial communications. The fifteen-pin port of the power supply module in the CPU is an RS-485 programming port. Depending on the CPU model there could be other available ports.
Does your 90-30 have an ethernet port on CPU or an add in module (CMM321)?
What CPU is it?
Have you connected to it before with ME (Machine Edition)?
If not... do you have the logic converted from Logicmaster 90 to ME?
I have connected to this just two weeks ago, prior to this event, over ethernet. The CPU has an ethernet port. I do not have the Station Manager cable with the RJ11 to 9 pin D shell. I may have to purchase one, but i really need this up and running on Wednesday
Had a cable overnighted, connected up to Station Manager, dl a free hyper terminal, did bootp with an IP address, connected with Proficy ME, dl the program, up and running today.
I was able to use the set temporary IP address tool for a 90-30 cpu374 using Proficy v9.0. I tried it first in v9.8 and the tool set temporary IP address tool is just not there so I tried and older version and it worked.
I'm getting frustrated creating arrays of variables in Machine edition. I need to make 2 variable arrays that are 102x2 in size, with varying...
105
Hi, I am still a beginner with PLCs and I have never worked with GE PLCs before so looking for some help. I am using GE Proficy Machine Edition...
1,377
I am trying to download version 9.8 of G.E.'s proficy machine edition, does anyone have a link to a download site?
5,145
Need to learn a few more tricks in Proficy Machine Edition. I don't use it often, but one of the first things I usually do when getting into a new...
1,021
I am new to the GE Proficy Machine Edition. Currently updating some logic on a Rx7i system using Proficy Machine Edition 7.5. The issue is that...
1,279
