GE Proficy Rising Edge Structured Text
obi1987
Jan 2014
lahore
114
Hi!
Anyone can share example of GE Proficy Rising Edge Structured Text?
I have found text as below
InstanceOfR_TRIG( CLK := inBool, Q => outBool,
ENO => outBool);
What I am getting from when the clk will be 1 Q will be1 for 0 to 1 transition.
Now what is the Instance is it my tag?Anyone can share with example it will be helpful.
Thanks.
You can do this a couple of ways.
1. Drag the R_TRIG instruction from the Toolchest into a structured text block.
It will ask you for a name.
The name you create will have a data type of R_TRIG.
2. You can create the variable first, then type it in the structured text.
Be sure to create the instance under the block. It may work as a global instance, but I would not recommend it.
When you create the variable, make its type R_TRIG.
When I am droping it from toolchest the same text just appeared in Structured Text block.
Variable should be the same which i have to use for Positive edge or it is just a new variable
For Example my Tag is P_PED
Var
Test : R_TRIG;
End_VAR
OR
Var
P_PED : R_TRIG;
End_VAR
Can you please give me an example?
GFK-2950 chapter 8 covers structured text and has many good examples. Also, there are R_TRIG and F_TRIG function blocks available if you don't want to do it in structured text.
EXAMPLE USE
VAR
(* Declares that we want a single variable of the function block R_TRIG
We name the instance "myRisingTrigger" *)
myRisingTrigger : R_TRIG;
bInput1 : BOOL; (* This is the input we will want to see the rising edge of *)
myCounter : INT; (* Counter for number of edges *)
END_VAR
(* In the program we use the function block instance *)
myRisingTrigger(CLK:=bInput1);
IF myRisingTrigger.Q THEN
myCounter := myCounter + 1;
END_IF
myRisingTrigger.Q is true only on the rising edge of bInput1, which you can verify by watching the counter.
Has anyone migrated Proficy Historian data to a new server? I followed the guide to move all the data over, but when I run the utility, it stops...
51
I'm getting frustrated creating arrays of variables in Machine edition. I need to make 2 variable arrays that are 102x2 in size, with varying...
106
Hi I am wondering if the RXI-042 PLC model (below PN) is programable via Proficy Machine Endition, if so, what is the firmware version needed for...
101
Greetings, I am working on a project and I would like to scale %AI to -10.0 to 10.0 VDC. The module Input data is stored as a 16 bit Integer and...
74
I am trying to download a program with usb to serial cable in rx3i IC695CPE305 while logic and configuration is equal but when i start downloading...
50
