GE Protection Relay with ML1400 communication
alijuda
Jan 2013
Iraq
62
Dear My Friend
Iam Very thanks for all Helps in this group , I get good information from your technical supports
I have 12 Protection relay type GE MIFII with RS485 intel format I would like to connected to PLC type ML1400 through RS232 -RS485 Converter
I intend to using MSG order which I used befor with LS VFD and succssed
Please any advice ,especialy RSlogix 500 dont accepted Hex addresses and I must convert Intel format to Decimal , is that will working
Many Thanks
Ali(y)
I've encountered a fairly new MiCOM protection relay that for some reason can only accept firmware updates via a 25-pin parallel printer port. The...
2,703
2,540
Hi All, I have a unique issue with resetting a Reyrolle relay after a communication break down. Anyone here worked with Reyrolle relay and IEC...
1,810
I have the power supply in the link below. If we want a breaker to isolate and protect the input side how would I size that correctly being 120...
204
I am having a step7 v5.4 program where the blocks are encrypted and locked. And the manufacturer is stopped the support. Is there any ways to...
181
