GE RX3I Analog Input card
jgunnels
Jun 2010
Vancouver Washington
24
Hello All,
I am setting up a new RX3I test Rack with random I/O cards and a ( Horner ) HE693ADC420 analog input card. I do have a running system to duplicate and have setup the config the same way on this card ( see attached ). using a fluke current source I am not seeing any change on %AI0001,2,3,4 ? any ideas on this? Also I have swapped out the horner card with a new one just to make sure its not bad. Any Ideas?
Using Proficy 9.8 sim 9 rack is on a IC695CHS016 16 slot rack
Joe
The hardware configuration looks good. The wring diagram shows jumpers between terminals 5 - 7 for channel 1 (%A1001), terminals 6 - 8 for channel 2, terminals 15 - 17 for channel 3 and 16 - 18 for channel 4. Are those in place on your system?
When you applied the signal from the Fluke and got no response, did you try reversing the leads?
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
124
I have a system using Rx3I CRU320 redundant CPU with Proficy Machine Edition Software. In the hardware configuration of each CPU module, under...
405
Hi, we are using Rx3i CRU320 redundant PLC system and we noticed a discrepancy between Primary and Secondary controller. Couple of variables (DI)...
303
Hi there, Trying to get some ascii serial communications working via RS485 (COMMREQ functions). I have attached our wiring for the COM2...
991
Hello all, First time poster, long time viewer of these forums. Could not find my solution on here. We have had issues with a Comm Fail on an...
410
