GE RX3i CPE305 serial port configured as "RTU Slave", trying to find address info
defcon.klaxon
Feb 2015
Far NorCal
616
Hi guys,
I'm working on a system with a GE CPE305 and the serial port is set up as a "RTU Slave"; from reading the documentation, this means the port is, "Reserved for the exclusive use of the Modbus RTU Slave protocol". This port is connected to a Red Lion DSPLE data converter which is accessing the CPE305 as a MODBUS master. This DSPLE is connected to the internet, and the data is provided to an HMI in the client's office.
Looking for further information about how this port actually works, I've come up lacking. I am trying to find info about how this port is going to work for accessing the different register addresses. Basically I'm trying to figure out how various registers are "converted" for Modbus RTU when there doesn't seem to be any actual configuration going on in PME. So basically, how would I access %R registers versus %M or %I or %Q, if that makes sense. I'll keep searching but was hoping someone might be able to provide some insight. Even reading through the 305 manual, it doesn't seem to explicitly describe how this works.
In Proficy Machine Edition hardware configuration for the CPU module there is a setting for Modbus mapping.
Hi Steve, I did indeed see that but I thought that was for Modbus TCP only. On my CPE305 module the table says "Modbus TCP Address Map". Because I'm using the Modbus RTU slave through the RJ25 connector, I didn't think that would be the right data but maybe I'm wrong? Checking now, all the data in the tables is greyed out and I can't adjust anything.
Hello all, First time poster, long time viewer of these forums. Could not find my solution on here. We have had issues with a Comm Fail on an...
394
I have a Project with multiple small sites that have pipeline valves. The client took the PLC from one site, and wants me to configure it for...
1,462
I know Once again I may be sailing in Uncharted Waters but thought I would throw it out there anyway. I have a Emotron TSA52-450 Soft Start with...
5,594
Hey guys, I am currently trying to communicate a cpe305 PLC with modscan32 in a computer.I am using the ethernet port available in the PLC to talk...
2,421
I have a problem loading the first configuration and logic to a new CPE305. This is about the 20th CPE305 I have setup. I have never had a big...
18
8,252
