GE Rx3i Modbus TCP
mjevans1
Dec 2013
New Orleans
Does anybody have any experience programming the GE Rx3i CPE305 along with an ETM001 with a SmartMCC that communicates via Modbus TCP? I understand that I must use the COMMREQ block for each read and write, but wasn't sure if there was an easy way to manage the COMMREQs. I was hoping someone has done something similar and can shed some light. Thanks
Here are the routines needed in a Toolchest drawer:
http://www.plctalk.net/qanda/showpost.php?p=591232&postcount=16
Remember, when you copy from the Toolchest you 'Drag-n-Drop' while pressing the Ctrl key.
To summarize:
1. COMMREQ to 'Open' Read Channel
2. COMMREQ to READ
3. COMMREQ to 'Open' Write Channel
4. COMMREQ to WRITE
5. Monitor both 'Status' registers for Faults.
6. On Fault 'Close' and start over.
...If too many faults in a row Flag for manual intervention.
Does the SmartMCC provide a single point of connection to get data from every bucket, or does each bucket have its own Modbus ID? One of the setup parameters for each read or write COMMREQ is the "Unit Identifier" which is Modbus ID of the server device. If you have to read each bucket separately, you will probably need to change that parameter value for each read or write COMMREQ. Unless you plan to open a channel for each bucket. The ETM001 can have 32 channels open simultaneously.
Thanks for your help. I believe I will create separate channels for each device and just open all of them then just start reading and writing based on some timers.
I'm trying to talk Modbus TCP/IP from a redundant system using Lan 2 inthe CPE330's to a CPU310 using ETM001. I've had the system talking before...
17
2,416
Greetings to the forum. Wondering what experience exists out there for this problem I'm currently encountering with an Rx3i controller. Have six...
6,737
Hey guys, I am currently trying to communicate a cpe305 PLC with modscan32 in a computer.I am using the ethernet port available in the PLC to talk...
2,431
After reading through some older threads and checking out my old friend GFK-2224, it sounds like an RX3i CPU can talk Modbus TCP, this much I'm...
1,481
Is this possible? I want to read values from a power meter directly into my PLC. Is there any kind of documentation on how to set this up? My CPU...
6,369
