GE Series 90 upload
geniusintraining
Jun 2005
SC
8,287
Hi Guys,
Trying to upload then download a program from a GE Series 90 using Versa 1.10
I know that I am a bit out of date on the versions but it is what it is...
Is there anything in the folders hardware configuration that will auto detect the PLC/CPU type? I am trying to set up the HWC in Versa and have no idea of what I am doing..
I just need to upload a program from the PLC, to make sure I can transfer the program
And before you say it (RTFM) I am a little short on time...
Mark
Using the adapter or going with a homemade cable?
It is Store to send the program to the PLC, Load to get it.
There could be issues if the plc was programmed with LM or newer version of VersaPro.
Have to make sure your com port settings match the plc.
AS you request (same as I do) offer details of the PLC, cable/adapter, etc. being used. Steve, RussB, or I (last man on totem pole) may be able to assist.
You have to set up VersaPro to create a new folder using the same type of PLC as the one you're trying to upload from. By default, I think it sets up all new folders as a VersaMax PLC. Once the folder is created, you can't change the PLC style. For example, you can't turn a VersaMax folder into a 90-30 folder.
Open VersaPro, but don't open any project folder. Under the "Tools" menu, select "Options". In the "General" tab, there is a field called "Default Hardware Configuration". Choose the PLC style you need. All new folders will be created using that style until you change it again.
I hope the program you're trying to retrieve wasn't created with a newer version of VP or with Machine Edition. That could be a problem.
rsdoran said:
Using the adapter or going with a homemade cable?.
very good!!... but yes, both
Thanks guys... it worked great :)
Its a very nice program to, I like it, little weird having the program tree on the right, but still a nice program
Mark
Steve Bailey said:
VersaPro lets you position the windows anywhere you want to put them, including letting them "float". If you would rather have the folder browser on the left, just click on the border and drag it to where you want it
Cool thanks :)
Hi All, i want to upload program from 90-30 Series Ge fanuc. Can any body tell me steps should i follow?? Also which Software should i use??i...
1,900
Hi All, I am New user of Ge Fanuc PLC,some body please help. i Have Ge fanuc series 5 PLC(Ic655) old plc,I want to upload Program from it after...
1,680
Hello, I am having problems when trying to upload the program from an ABB 07KT97 PLC via serial communication. I can connect to PLC and read some...
3,049
HelloI need software to download the program from PLC EH-A28DRP from an old machine whose manufacturer does not exist. It may be Ladder Editor for...
75
70
