GE SNP protocol CPU identifier string
Pierre
Apr 2002
Montreal
1,669
Next week I will meet a guy to update some of his SCADA database client.
When I talked to him today he asked me a question about GE SNP protocol.
He says he cannot establish the communication because he can't get the PLC CPU identifier String wright.
Here are the instruction from the help file concerning this driver.
PLC CPU identifier String. This entry may consist of up to six characters for the Series 90-30 and seven characters for Series 90-70. If configured in a multidrop network, this field has to be configured to match the PLC CPU ID. The default is a Null string which may be used to communicate to any PLC regardless of its CPU ID.
He has a stand alone 90-70 PLC so it seems that he don't need any string in this field (null string?). Is this OK or is there some more I should pass along to him. I have never use the 90-70.
The app. is ParagonTNT5.50 SCADA
Is there any documentation on GE FANUC SNP protocol with source codes and possibilites to read and write data on Versamax? Modbus is very limited...
1,575
Hi Folks, especially anyone who remembers the GE Fanuc 90-30. We've got one , and an old XP laptop , with a converter cable, and ECLiPS . We...
2,910
I'm trying to establish snp serial communication between GE Fanuc CPM-790 programmers port ( 15-pin, RS-485) using 4-wire connection. On the PC...
3,200
Hello, I am trying to set the SNP ID on a GE Series 90 micro controller. I connect to the device in PME and when connected I am not able to edit...
1,909
I pulled the power supply and first module to have a look at the CPU Chip I Read the Label "395-027C- 6.51" I "***-umed" that implied a revision...
1,952
