archie02
Good Morning all can you help/advise me im have a configure ge9 driver Called ge9.ge9 path is (C:\Program Files (x86)\Proficy\Proficy iFIX\ge9.ge9) is i want is to make it the default.. i set the default configuration file name C:\Program Files (x86)\Proficy\Proficy iFIX\ge9.ge9 i set also default path for configuration file in C:\Program Files (x86)\Proficy\Proficy iFIX\ and Press SAVE and SCU save configuration
BUT when i OPEN again the SCU>GE9>use local server connect>how come THIS (C:\Program Files (x86)\Proficy\Proficy iFIX\Untitled.ge9 i double check my default path under power tool C:\Program Files (x86)\Proficy\Proficy iFIX\ge9.ge9 i set also default path for configuration file in C:\Program Files (x86)\Proficy\Proficy iFIX\ (same) i want my default is C:\Program Files (x86)\Proficy\Proficy iFIX\ge9.ge9 what is wrong? why this Untitled.ge9 keep on going even do the save my SCU configuration
i installed the ge9 driver on C:\Program Files (x86)\Proficy\Proficy iFIX
info
OS-XP
GE9 version 7.19b
Ifix 5.8
Any suggestion and comments is lovely appreciated thank you
info
OS-XP
GE9 version 7.19b
Ifix 5.8
