General industrial question - CCTV to Screen
plc-girl
Sep 2015
Manchester
18
Hi there, I have a small PLC system with an HMI on the panel, but it is not good enough to show live feed from a CCTV camera.
Has someone worked with a simple system, where I can have a direct cable from the camera to the screen, with no PC/logic in between?
Ideally the screen should be idle and only turn on on touch or similar.
Thanks!
Schneider's xbtgt series of screens can take camera feed straight from camera and display it.
not sure about what type of feeds it support but you can go on their website to check the catalogues
Those are HMI panels, I am looking for a basic screen that I can plug-and-play, only option would be for it to go idle when not used.
We just have a multi camera cctv reciever and a TV where we need something like that. They are made by multiple manufacturers.
You asked for a screen that can display a camera input with no PLC in-between, that's what the XBTGT (it's now the XBTGTO) will do.
Why don't you approach the CCTV camera manufacturer or supplier, they may be able to help ?
There is plenty of stuff like this online:
http://www.pcworld.com/product/1419072/viewz-touch-screen-lcd-cctv-monitor.html
What is your perspective? Are you a Maintenance Tech? Systems Integrator? OEM Engineer? What are your thoughts on the topic of source...
24
1,177
Wizards, It has been a few, but you all have always done me well. I have acquired a 1769-L33ER and want to use it as my collection PLC to...
534
Hi! I recently discovered how to get to configuration mode and disable printing for connecting to PanelBuilder32 and updating my Panelview...
454
Hello Guys, Hope everyone is doing well. I have a general doubt about ladder programming. The outputs are not getting energized when I used the...
1,886
Hey all, I'm teaching myself PLC programming, and don't have a lot of resources at my disposal, so probably a very basic question, but I recently...
2,426
