Generation of L5K/L5X File for Studio5000
maanwr
Jun 2020
Australia
Hello Everyone!
Hope you guys are doing well during this pandemic.
I am trying to auto generate L5K file for Studio5000. The AOI is in encoded form in the L5K/L5X file and all the different version of the PLCs containing same AOIs have different encoded data. When I open the AOI in notepad++, the encoded data is different from the L5K/L5X file as well, it means that the encoded data is not consistent.
I have tried to open the L5K/L5X file without AOI encoded data but it's giving me error that data is missing.
What options do I have?
Hello Everyone!
So you have:
- several PLCs with an AOI loaded
- the internal AOI data is not the same for each PLC
AOIs can store a variety of information inside the structure.
Is the AOI from a vendor, and does it reference a rack/slot ... or perhaps give you an interface to an ethernet device?
If the AOI data is not the same between PLCs, I don't think you will be able to force it to be the same. If you do manage to get the data to be the same, I don't expect that it will operate properly.
Why do you think that this is an issue? If the internal data is different, there must be some code inside that configures the data. If the AOI configures itself ... where is the issue?
Good morning all, I have a project that has quite a few NATRs to configure. I would like to modify the generated backup config file because I...
446
Hello. At my job I get from clients lists of their inputs and outputs (hundreds of them) and what they want the program to do. So I have to type...
1,351
Hi, I am very experienced with TIA Portal, however I think I could be doing some things much quicker, one of those things is alarms! On some...
20
6,331
Hlo All,, Greetings:bow: I need to find some softwares which can import data from plc tags or hmi and log in my pc in anyway. kindly let me know...
1,274
Hi everyone! I have a question to all of you guys - do you ever use any software or online tools to manage your automation/electrical...
9,349
