1783-NATR Configuration File Generation
cdewitt
Jan 2022
Indiana
Good morning all,
I have a project that has quite a few NATRs to configure. I would like to modify the generated backup config file because I could write a script that will generate the rules and set public and private addresses. The problem I'm running into is when I try to load a modified config file I get the following fault "The configuration was unable to be restored from the SD card."
I think I've narrowed it down to some sort of checksum issue by changing the config through the web interface and comparing the files. One of the first lines in the XML backup file is <_1783-NATR SerialNumber="8445af24">. The SerialNumber isn't actually the serial number of the NATR and seems to be changing every time I change a setting.
Does anyone have any experience configuring these with the backup XML file or have any ideas how that value may be calculated?
Thanks, I tried leaving it out and I'm getting invalid format still. I've tried hashing a few sections so far but haven't had much luck yet. It looks like it's either CRC32 or CRC32b since so far those are the only 4 byte hashes I've found so far. My next plan is to change settings one at a time and see if I can't find any that don't generate a new hash to maybe figure out which sections in the XML to generate the hash for.
Good Morning everyone. Trying to install a 1783-NATR comms module on a system with a CompactLogix L32E processor, An unmanaged switch with a 3rd...
3,108
Is it possible to gather OPC data through a 1783-NATR? Searching around, it sounds like OPC data might be blocked by any NAT... Is there any work...
248
I am trying to communicating with other PLCs on a public network from a CompactLogix PLC on a private network. I have installed at 1783-NATR...
556
Hello, I'm seeing some interesting behavior with my NATR connections on FTLinx. 2 separate cases are showing the same problem: The first NATR...
622
Hello, I have been trying to set up a NATR with 3 connections, I am able to ping the public IP of the NATR itself off of my network, but nothing...
680
