Getting an upload from a GE Quickpanel View HMI
technolog
May 2015
Ohio
320
I need to try to get an upload from a GE Quickpanel View HMI, IC754VSI06STD-KH, model: ES0611.
I saw the thread
http://www.plctalk.net/qanda/showthread.php?t=126986
I have Proficy Machine Edition and have added the QP View 6" STN Intermediate (IC754VxI06STx) as a target to an otherwise empty project. My question is, can I upload via the Ethernet port or do I have to use (what looks like at a quick glance) the 25-pin serial port? If the latter, does anyone have a part number for the appropriate cable or a pinout?
Hello technolog,
You able to upload the project or not?
Please answer me cause i have the same HMI as you.
And if yes, please share with us the steps and the software you used.
kind regards
Would someone be kind enough to tell me what software and cable I need to be able to get an upload from a Siemens S7-200 with a CPU214? Its part #...
2,839
Hi how's it going. Was just wondering if someone could help me out. Recently one of the guys over on the LinuxCNC forums put me onto getting an...
333
The application was working in Twincat 4022.16 Used VM for offline. recently changed the laptop and the getting the error with Message as below...
84
We are using wincc scada WinCC system software V7.5 SP2 , connected to few plc . Past 3 weeks we getting this alarm continously when we checked...
115
I am very, very new to PLCs. I only have experience with Picos, but I knew enough to save this from the dumpster. Apparently, everything on it is...
711
