Global Object Help
PLCNooooob
Nov 2022
Louisiana
Good morning everyone! I have been searching for what feels like an eternity, trying to find a solution to my problem.
I am using FactoryTalk View Studio ME v. 12 and have a global object that I use to display values and other info from four different types of transmitters: pressure, level, temperature, and flow.
I have a series of box that become visible if certain parameters are met through the tags and the data all displays correctly and my animations all function as desired.
I currently am using 4 different global objects with different labels for each type of transmitter and I have been trying to find a way to have the text box display different text depending on the type of transmitter.
I am currently using two global parameters, #1 and #2. I will give examples of how I am using them.
#1 = PIT
#2 = 1001
My UDT is in the PLC as "PIT_1001" and so I reference the tags by "#1_#2" and my name for each display box uses literal strings "#1"-"#2" to generate the name "PIT-1001"
I have separate boxes labelled PALL, PAHH, PAH, and PAL and would like them to change to LALL / FALL / TALL, etc. if the value of #1 changes from PIT to LIT / TIT / FIT.
If anyone can come up with a way to help, I would appreciate it.
Try a multi-state indicator instead of 4 boxes. Then write an expression to display the states.
If #1 = "PIT" Then 1 Else
If #1 = "LIT" Then 2 Else
If #1 = "TIT" Then 3 Else
If #1 = "FIT" Then 4 Else 0
Then Label each state as needed and leave 0 blank.
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
135
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
178
Hi everyone, I am trying to add a control loop to my HMI interface however I keep getting the following issue, any idea why this would happen?
1,623
Hello, I'm having an issue that I did not expect to run into. Using FTV SE v11.0 (CPR 9 SR11) I've created and saved a global object inside the...
1,519
Greetings, Currently trying to Improve the ability to troubleshoot DLR issues at one of our production lines. Found the "NetworkDeviceLibrary...
1,313
