Gml commander
agiusm1
Mar 2008
malta
I am trying to connect to my servo controller however i have an old version of the gml commander 3.8.2 and apparently the servo controller has an other version which i dont know which? does any one know what i can do in the intirm until i get hold of a more recent version
10x
Please post the model name, the part number, and if you can determine it, the firmware revision of your servo controller.
The last GML Commander release I am aware of was version 4.03, released in 1999. The features it supported corresponded to firmware revision 3.9 in the 1394/IMC controllers. The earlier versions of GML Commander 4.02.00 or 4.02.01 corresponded to 1394/IMC firmware 3.8
The predecessor to GML Commander was called "GML 3" software. GML3 version 3.9.1 works with ALL 1394/IMC motion controllers but only supports the feature set up to 1394/IMC firmware 3.5. If your controller is using features from after 3.5, you're going to need GML Commander.
I doubt there's a stocking RA distributor on Malta; who do you buy your equipment from ?
Motor Type confuguration
I have a problem:
How to set Transducer Counts/Mtr Rev and Motor type for Drive/Motor 1394 configuration in GML 3.9.1 (IMC 1394 S Class Compact,4100-234-RL)? The motor is Lenze MCA21X17 with 2048PPR TTL Encoder (A,A not,B,B not and Z,Z not) and Lenze EVS-9327-ES Servo Drive.
1394 Assistance Needed I have qty 8 1394 units in various states of repair that I need to repair and test. 1394C-SJT05-T 1394C-SJT05-T-RL...
2,094
We have a machine with an Allen-Bradley 1394-SJT10-C multi-axis motion controller with two axis modules, both 1394-AM75. One of the axis module's...
20
10,176
GML Commander, OKIEPC, I am trying to contact you, your inbox email is full, please contact me asap. I am in OKC, OK., I can use your experience...
1,739
I have a 1394c-SJT05-C-RL Servo controller. The unit powers up. I cannot communicate using GML Commander. The light is blinking red on/off. Any...
1,918
Where can I obtain a copy for use with 4100-234-R IMC ?
1,957
