going in stop condition
i am working on s7 cpu 414-2 DP . on simulator when i click on run the program starts running and after a certain time it comes to stop condition again. the hardware diagnostics this detail is giving:"Explanation
This event is triggered whenever the start-up information is modified and when illegal commands are entered. When the situation preventing startup is only temporary (for example when configuration data for the distributed I/Os is being loaded), the command can be repeated.
The current start-up information is available in the detailed information for the event."
You need to interrogate the Diagnostic Buffer - go to the menu PLC - Diagnostic/Setting - Module Information and then Diagnostic Buffer. This will hopefully point you in the right direction.
(* menu options are from memory so may be slightly out..*)
I have an S5-135U. We had a problem in the past where if we unplugged our Siemens M4 PG while still in Windows but offline and out of STEP5. The...
2,967
I'm using 317-2DP for hydraulic drives. Where plc controlling 5 pumps by indvidual setpoint of 4-20ma. While starting the system PLC is going to...
4,160
pls can u tell me cause for UAFEHL interruption and plc going to stop mode i m thank full to u best regards mohammad danish
1,984
I've a Siemens S7-300 cpu (with two DI, two DO and one AI) card. The problem is that all the I/O cards have gone into SF (system fault) with solid...
16,455
Hi All, I have a S7318 and it will not go into Run Mode. The Diagnostic Buffer says 'Stop caused by Error When Allocating Local Data'...
4,002
