317-2DP going stop mode
rrajkumar86
Dec 2010
I'm using 317-2DP for hydraulic drives. Where plc controlling 5 pumps by indvidual setpoint of 4-20ma. While starting the system PLC is going to stop mode and diognostiocs showing the following error
Event 1 of 100: Event ID 16# 4548
STOP caused by I/O management
Previous operating mode: RUN
Requested operating mode: STOP (internal)
Internal error, Incoming event
07:32:53.457 AM 12/23/2010
Event 2 of 100: Event ID 16# 2943
I/O access error, writing
P area, word access, Access address: 568
Requested OB: I/O access error OB (OB122)
Priority class: 1
External error, Incoming event
07:32:53.457 AM 12/23/2010.
OB122 already loded in the blocks. Access address error is comig for PQW560-PQW606.
So i have started the drives one by one while starting 4 drives system is running smoothly. when starting the drive 5 PLC going to stop mode with the same fault. Please let me know if you have any idea on this to [email protected]
Raj
Hi, i've got something funny and disturbing... I've made a Sivacon switchgear PLC project, used in many PLCs across 2 years. To make a new...
3,813
hello I need your help, as I can compress the program and send it to CPU 317 - 2DP from Siemens STEP 7, I have damaged the memory card and the CPU...
2,807
I need to replace a Siemens CPU315 2DP with a CPU317 2DP, but it comes up with error: "CPU too wide". Physically the CPU is wider. How can I...
7,524
Hi, I have a MMC card-2MB(6ES79538LL110AA0) on the CPU-317-2dp. I usually download the blocks from simatic manager using the option PLC/Download...
4,150
Hi Could someday explain to me how to do the setting in the communication tab of the CPU properties option. Did read the help but couldnt...
5,211
