good flexible scada s/w
kiegmann
Apr 2006
Winona, MN
26
I am wondering what would be the best scada s/w for several different PLC types. We have Simenes S5 and S7, a gaggle of Mitsubishi FX, a few IDEC FA-2J, a Honneywell IPC620 and a few odd ones here and there. PLus there are a few non PLC controlled presses that we may want to monitor.
TIA
Mike
GE's Intellution has a large number of I/O drivers available. I use the Allen Bradley ABR Ethernet I/P, Modicon MBE Modbus/TCP, Modicon Modbus MB1 and GE Fanuc GE9 drivers with excellent results.
To be honest, as long as you can find an OPC server (I/O Driver) to communicate with the PLCs, you can use just about any SCADA package you want. Most of the big names in SCADA software offer a variety of OPC Servers for connecting to different PLCs. And you can also purchase 3rd party OPC servers as well.
So your answer depends on your needs and how much you are willing to spend. I would start by making a list of all the equipment you want to communicate with and then get in contact with these manufactures –
Wonderware – InTouch
Allen Bradley – RSView
GE – Intellution
Citect
National Instruments - Lookout
I'm sure others will be able to add to this list.
GE – Intellution
Citect
Missed from list
GE -Cimpicity
Siemens -WinCC
KepWare makes an excellent OPC server with many available drivers, and will work with any OPC compliant SCADA software. I have also used VB to develop, and they provide good examples.
NETSCADA is always my first choice. It has unlimited tags on each license. You are only limited to number of terminals or servers per license that are forever expandable.
Thanks all for your help. I will check them out. BTW, how are any of these for production recording/reporting and job scheduling?
m working on wincc2008 flexible Scada, what should i do to generate a message on cell phone on the arrivel of any fault (mentioned in the program)...
1,069
Hello all, I want to Control & Monitor 8 different S7-200 CPU 226 PLCs through Wincc Flexible SCADA. I am trying to communicate through...
7,050
Hellow A customer of ours has many MP377 HMI's in his company and wants to be able to control everything from one PC in the same way as the...
17
14,505
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
308
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
119
