GP Pro-EX Read CSV File
Killercal
Aug 2006
Ontario
150
Hello all,
I'm using GP Pro-EX to program some HMI terminals for a line. The line has 4 terminals, all with the same screens. On some screens I've got a script that reads text and PLC addresses from a CSV file that is located in the USB slot of each terminal. Now if I have to make a text change to a screen I have to make the change in the CSV file for each terminal.
I was wondering if there is a way to do a Read CSV File command over an ethernet network to a computer? If so, I would only have to change one CSV file instead of 4.
Any help would be great.
Scott
I've got a client who wants to pilot a Schneider's M580 controllers in Unity Pro and use their OFS OPC server to read tags straight out of the...
1,344
Good morning to all... I am a new bee in C# to GE Fanuc Versamax Pro PLC communication..... So I want to read/write registers values using c#...
3,607
I am new in PLC please help me to read data registers of energy meter (TRINITY tinypro-6) i tested on M-Tester it is showing values from range...
1,824
I have a Panasonic FPΣ PLC that has register values that have changed, how do you read them and update your program. If you try to upload the...
2,786
Hi All, We have a setup of a Wago 750-873 (ethernet controller) with a 16DI and 16DO module, progarmmed in CoDeSys We use a Pro Face screen...
7,913
