GPPW MItsubishi
Downiepd
Mar 2006
S.Wales
I have GPPW Misubishi software.
Is there software available that will interact with this when running a programme so you can see how your programme runs.
See actual movements/Delays.
You can use the Online-monitoring function of this program and "see" the state of bits and rungs and timers. Is this what you meant?
NO. If I was to programme a specific movment lets say an hydraulic cylinder moving forward I would like to see this visually happening on my monitor. Possibly in block diagrams.
There is a program that is like a visual aid but it does not work with gpp-win or gx dev. Its a stand alone program that uses mitsi ladder in one half of the screen and a visual virtual machine in the other.
To be honest, I thought it was poor and not for real programmers.
Its sort of for management that program one of the examples (like an auto garage door) then they can proclaim that programming is easy and they dont know what all the fuss is about.
I can't remember the name but it does exist.
There is also an add on to gpp-win called LLT (logic ladder test)
This simulates a real PLC without one being connected.
You can program timelines for different inputs on and off and it is a very good first test of your logic.
Hi, Does anyone know for Mitsubishi Gppw Software, can it support USB port ? As my new laptop does not have serial port only have USB port.
10,002
Can anyone explain with the aid of a ladder diagram how to enter a subroutine into a programme. The plc in use is a FX1n. Thanks.
2,956
How do you enter a subrotine command using this software. Does anyone know of a user friendly book for this type of software.(GPPW) Is the command...
2,632
Help. I have a problem doing a mod on a machine we have. After doing the mod then trying to "convert". The message - "It is beyond the program...
1,965
