Is ground loop problem on multiple current analog signals depend on the hardware (i.e. PLC) or on the signal generator (i.e. pressure transmitter)?
I have had an application before that requires me to use 4-ch AD module (in that case Mitsubishi) connecting 2 0-10Vdc (inverter) & 2 4-20mA (auxilliary out of temp controller & motorized pressure regulator). I have no problem with connecting the Vin but upon connecting 2 Ain, alas I had error on both device. I searched on what might be the cause & found out due to ground loop.
Another application I did using 2 Ain (2 pressure transmitter) was with keyence. I connected 2 4-20mA on the AD module but no apparent problem occur (hmmmm).
This leads me to ask the above question. Please help!
