PowerFlex 753 ground fault issue
Well...
After replacing the line reactor, we placed the pump in service and it has been running for about 25 hours without issue.
Learn something new everyday.
Makes no sense. The GF detection for a PF750 drive is based on the OUTUT current sensors doing a residual current detection method between them, resulting in a 25% difference, it's not like a GFCI type circuit. Something on the input side would not be seen by that at all. I'm assuming here that you got an F13 fault, right?
I'm more inclined to believe that there was some sort of internal moisture or condensation in the drive, and in having it unpowered for as long as it took to replace the reactor, it dried out.
But he had already changed the drive before and still had the same ground fault issue, correct? Unless your new drive captured the same moisture in the same spot inside your drive causing the ground fault. Did you try adding an air line into your cabinet with about 5 PSI, so as not to let any moisture get into your cabinet?
How to remove faceplate from power flex 753 and not shutting the system down. What parameters should i change?
109
Hi all, I am having a problem with a powerflex 753 we have on site and keep getting input phase loss. The drive has been running for a long...
1,364
Hello Friends, We have a powerflex that stopped working sometime last week. It doesn't communicate over the network, or use CCW directly from my...
457
Hello all! I am fairly new to the world of PLC's and this forum, so I apologize for my lack of knowledge. I have a Powerflex 753 that keeps...
563
I am bench testing a PF753 (20f11nd096aa0nnnnn). I replaced the IGBT's and IC's in the firing circuit. Upon power up, I get the STS light...
723
