GSV, Wallclock, Time? - RSLoigx5000
ebolbol
Apr 2011
CA
175
Seniors and Experts, forgive me if this has been covered 10,000 times. I have yet to see the subject function work properly in any of the plc's put in by our integrators! Always having to jockey numbers around for DST and such... I mean plain and simple, what's it take to have all the controllers follow the main workstation? (i.e. the main computer with all the projects and Logix licenses?)
Best regards,
Ed
Try this...
Run the Logix5000 Clock Update tool found in the RSLogix5000 Tools Directory
i think go the controller properties>date/time/set date time,work station,then go the program take gsv instruction date and time take local time and now make the tage having some array one dimensional in the destination...then you can get first array element as year.month.dtae.time...etc...
I also use the clock update tool and it works great! I also have all of our panelviews set up under global connections to update from the plc time and it sure makes it easier to keep their time correct.
Sorry md.abdullah, it's hard to follow your writing... :confused: I have attached what I see in the logic... I think? that is what you are talking about.
Thank kentuckytech,
I think I will try that. We also have our PanelViews set up under global conn. to update from plc and it does work good. Its keeping the time in the plc straight. So you basically have the GSV instruction with Wallclock DINT[7] array and running the clock update tool that's all? nothing else?
Yes, that is all we are doing.
thanks kentuckytech,
two more quick questions... 🤞🏻
1. Does the tool have to be running minimized in task bar continually?
2. I took a snapshot of workstation time, and plc time and
how does 16 equate to 8?
To answer the first question: no it doesn't have to be running all of the time but you would want to run it when you needed to update the time on your devices. I leave mine running minimized. I don't know the answer to the second question but i do remember updating the version of clock update tool early last year and i was having issues with the time zones not adjusting the controller time correctly so i reverted back to the earlier version and the problem went away. I'm currently running version 2.4.0
Hi Guys, I am trying to get the PLC wall clock to trigger a reset. I have gone through various posts on PLCtalk website and other website did...
3,441
I'm trying to dig to the source of a minor "recoverable" system fault throwing a fault light on a machine that has been confusing my operator...
89
So, I'm really just trying to get some experience by practicing with arrays. I'm using studio 5000 v33. I have one rung with an XIC bit that's...
239
Hello all, I know in the past it's been the case that we wanted to limit the total number of GSV calls per scan of the PLC. Is that still the...
663
Hello, I have a question regarding the status checking of the module in the secondary chassis in a redundancy setup. CHASSIS 1 ...
1,136
