Guardmaster Configurable Safety Relay 440C-CR30- Few Questions ?
Cydog
Feb 2018
Maryland
313
Good Afternoon ,
I'm having my first experience with a Guardmaster Configurable Safety Relay 440C-CR30. So far , I really like the product. I just have a few questions.
> Have any of you brought any information from the 440C-CR30 into a
Panelview Plus , to show the status of light curtains , muting switches ,
gate locks , etc. ? If so , what is the best way you found to do this ?
I tried to find the 440C-CR30 in FactoryTalk Linx , I'm using Ethernet
using the 440C-ENET on the front . What is the best way to access
the 440C-CR30 and "drill down" to see the staus ? I'm using
FactoryTalk View ME .
> Also , you can just add this in the same application with your other
PLC shortcuts in the same HMI application , correct ?
Thanks so much in advance,
Presuming there is a Logix controller the PV+ connects to, just add the 440C to the controller's IO 'Tree' using the available AOP and then use the info from within its own Input and Output EIP Assemblies for 'feeding' the FTVME application regarding the status/state of the devices connected to the 440-CR30 relay.
Good Evening , I have some Rockwell Light Curtains and Guardmaster 440C-CR30 Configurable Safety Relays . I was wondering if there is any...
1,393
Hello all. I am purchasing a CompactLogix to use as a server which will host 4 other PLC's (2 ControLogix, 2 Beckhoff) and a Fanuc RC. The current...
920
Hi All, On our site, we normally use trapped keys for our safety gates, however, for our newest project, I have been told that we will be using...
1,013
I am working on a project where an AB Guardmaster 440C is the logic solver for some SIL-rated interlocks. I need to be able to send reset bits...
747
Wizards, A little something out of the norm, I have a LoTo station that someone built for training purposes. It never got completed and the box...
1,981
