Guidance on project modelling / description
treaney
Jun 2008
Claremorris
I'm starting a new PLC control project and would appreciate some guidance on how to do things right.
I need to model/describe what is it that I need the machine to do. I am familiar with the waterfall model of software development(from Wikipedia):
  1. Requirements specification
  2. Design
  3. Construction (AKA implementation or coding)
  4. Integration
  5. Testing and debugging (AKA Verification)
  6. Installation
  7. Maintenance
I can write it down and describe the functions. What I want to ensure is that I'm using an industry standard representation. I can do a flowchart by hand but would prefer to do this with software. Any pointers as to where to find a template for an automated machine would be helpful. I'd love an Excel spreadsheet model to help with this.
Thanks Lancie - an impressive piece of work.
I'll send some time to figure it out. It will certainly help in what I am attempting to do.
Treaney,
You probably call them "lifts" over in Ireland.
Each cell of the Elevator spreadsheet was a rung on the original relay ladder logic schematic drawing of the elevator. The schematic drawing (and the actual elevator) was all I had to work with in making the simulator spreadsheet.
We do indeed call them "Lifts". Also lifts go from the Ground floor to the First Floor to the Second Floor...
I'm still working on understanding your Elevator Excel spreadsheet.
One important thing to know: Rung contacts in parallel (on separate rung branches) translate to Boolean "OR" statements in the Excel spreadsheet. Rung contacts in series translate to Boolean "AND" statements. Normally Open switch contacts on the schematic = Contact Name in the Excel spreadsheet, while Normally Closed contacts = NOT Contact Name.
Some time delays are created by applying a 1-second Macro delay for however many seconds delay is needed. Closing or opening the elevator door requires 5 seconds, so Macro routine A8-delay is run 5 times. The two physical timers T3 and T9 are simulated by adding 1 to a number in the cell below the timer, until a certain delay value is reached, 8 for T3, 9 for T9.
To operate the "lift", enter a "1" in one of the 12 floor pushbuttons (1 on each floor, 6 inside the car), then press the RUN pushbutton, or type Ctrl R to start the Macro. You can see the various relays switch from 0 to 1 as the door closes and the car moves. At the end of travel, the relays switch back to "0" or deenergized, and the door opens.
I will advise you if you can, to start looking for S88.
We are working now with that, and I can tell you this, it is very hard at the beginning, but when you understand it, its nice. You can live without it...
So, my job is pretty much giving me a PLC lab to train with. I just finished up some basic analog signaling and processing using a process meter...
8,991
Hello all, This is my first Siemens project, I am familiar with Rockwell, but just a lil lost on the way Siemens does things. I am using TIA...
3,719
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
212
Question to anyone with ideas about my thoughts on upgrading a very vintage timer, which is being used to switch between 2 5hp domestic water...
440
Hello All, We have assembly line and our supplier building automated line on top of it we are interfacing mes system. Our automation supplier...
285
