Mas01
Daft question coming up...
Which instruction should I use for this water level code? This is for float switches mounted on a vertical pole.
The MOV command can't be correct because, for example, if X75 goes TRUE , D612 is set to 25, but if it goes FALSE again, the value of D612 is retained.
Which command should I be using so that the D612 changes depending on float switches?
