stretch_af
Sigh, DeviceNet noob...
I have a 1756-L55, with a DeviceNet module, and 10 PF700 all commanded with DeviceNet. One of the PF700's blew up recently.
There is a New PF753 fitted with a 20-Comm-D module (in Port 4) that I am trying to commission in its place.
To make things fun, there is also installed a 2262D-2R installed (in Port 5) for a remote Auto-Off-Hand selector switch, so that the drive can run without the input from the PLC.
I have the parameters for Hand function set, it does run in manual using a preset reference.
As for the DeviceNet, I have the scanlist and the Inputs and Outputs for the PF753 remapped accordingly. DeviceNet Diagnostics is happy.
The PF753 receives the start command and starts. Commanded speed stays at "0.00" however.
The controller is issuing a reference of 3300, that should be 33 hz.
P545 - is set for Port 4 Reference.
P874 - Port 4 Reference reads 0.00.
I have been pouring over manuals, I can't find what I'm missing.
Why isn't the speed reference making it into the drive?
