gx developer analog output help
Matnim
Mar 2015
london
I'm trying to programme a gradually increasing analog using and fx1n and a fx2nda unit. The output needs to increase over a set period of time and then hold at the final value. Can anyone Help?
Cheers, Matt
Cheers, Matt
Can you be more specific as to what you are trying to accomplish and perhaps post what you have so far?
You will need the manual for the Fx2N-2DA unit to find programming examples for setting the module up. You will need to write some setup stuff using TO/FROM commands, i.e. enabling each channel, channel configuration, resolution, etc. Also you will need to write to the module to tell it what register the digital value to be converted is in.
Hope this helps,
Dave
Hi! I like to ask is there a way i can filter my analog input?
1,131
Hi, i have a pressure sensor (range 0-10 bar) and its output is 0-20 ma. but the current vs pressure curve is non linear such as. pressure...
2,079
Good Evening, I am an under graduate engineering student presently working on a project involving the Mitsubishi FX3G PLC. I plan to programme...
8,556
Good day all. I've used the "intelligent function utility" within gx to set up Q64DA and Q68ADI modules. No hardware yet, so can't verify, but...
2,650
Hello, When I try to read from the PLC, the following error occurs: There is no project name. Failed to read the intelligent function module...
90
