GX developer comms error
Mar 2012
colchester
HI Guys
Hope you can help.
Using GX developer with a range of plc's. When trying to write to plc all I get is a selection of problems, ie: Comm error - cable error etc. Tried the usual, transfer details and changing usb cable etc.
AAAAAAGH!
Many thanks
JOhnD
When you get communication error upon trying to go online with a PLC, please check if the PLC model you have chosen is the same as what is connected, if using serial connection check the com port you are connected by reviewing your device manager, change the transmission speed if necessary.
If these all fails, you may have a problem with the software installation or your cable. Try to re-install the software & find yourself another cable.
Please check also that your software is compatible with your OS. Older version of GX only works with windows xp or vista, not on windows 7.
I hope I have been of help.
Thanks for reading this thread, I'm using gx dev v6, recently I lost comms to any of my plc's. On checking the settings I notice all the comms...
2,513
Hi all hope you can help. I have installed gx developer v8 into the win 2k partition of hp laptop (dual boot to win 2k/sp4 or win/98 v2). I...
4,567
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
53
Well, I've decided to start a new project, and like all projects, it has already gone horribly wrong. I purchased a PLC device (supposedly a...
113
Does anybody have any samples of how to "Create and Use" UDT's in CCW Developer Edition? (I am using v22) I can't find any information from...
314
