GX IEC Developer update
mppdk
Apr 2010
Skagen
Hey
I have IEC developer v. 6.10, and i have a program that is v. 7.01
Can i somehow update my version or convert the plc-program so i can open it??
Best regards MPP
As far as I know - NO!
You could try to make an ASCII-export of the program, and then import this copy with your 6.10-version of GXIEC. If that doesn´t work, then I would suggest you buy a newer version of GXIEC.
I have done this with a GX Developer pgm and it might work with iec. Create a project with the older version then transfer the file named "BROWSER"(this contains all the pgm code/logic). from the newer version into your older version and then try and open it hope it works Best of luck.
I tried to update my Mitsubishi GID 7.01 FX => 7.03 FX. The update seemed to damage an other Mitsubishi program in my PC (GX Developer 7) so that...
8,597
Hi, Lets say I have a bit of code where I have used the Mitsi address "M6" several times. I then decide to declare this M6 in the Global...
1,892
Hi everyone, I'm working on a Mitsubishi Q series PLC whose code was developed in Mistubishi's GX IEC Developer v7.04. I looked online for GX IEC...
1,482
501
Hello, i want to do a device backup but can´t find it. Someone remembers? :huh:
882
