GX Works 2 Program COmpile Error F0160
ashish007pict
May 2012
india
I am using GxWorks2 for PLC programming and configuration. I have 47 routines in my Program. After build I am getting following error. Please suggest necessary solution.
Error Class: Program Compile
Error Description: Device or Address is out of range. Please check the device setting in PLC Parameter.
Error Code: F0160
Please help me as this is wasting lot of development time.
Hi, I am using GxWorks2 for PLC programming and configuration. I have 47 routines in my Program. After build I am getting following error. Please...
3,836
I am noticing a problem where i am using MOV instruction and writing literal text into source and String datatype in destination. It works fines...
491
Hi, I'm learning GX Works 2 for upcoming project. I want to use ST Function Blocks in Ladder Program and it works if the FB(Structured text)...
1,687
1st off I'm very new to WonderWare, the program am i needing to modify is version 10.1 The issue that i am having is that while the program...
665
Is there a way to merge comment from two PLC programs in to one for GX Works 2? I read from a PLC and got the code back with no comments, I then...
6,093
