Hackers 'hit' US water treatment systems
I've been hearing a lot of talk about this "SCADA" thing on the airplane and in military circles who don't usually mention it. A similar technique was presented at the Black Hat hacker conference earlier this year. You can bet that such systems are now in public view.
That story out of Illinois smelled fishy from the beginning. I mean, who cycles a pump to failure as a form of "attack" ?
This is an unfortunate "conspiracy theorist" type story.
My company had remote access to many different utility sites. This has saved us and the utilities thousands of dollars by allowing remote tuning and troubleshooting instead of buying a plane ticket. We generally set up our systems so that onsite operator intervention was required for access - usually physically plugging in a cable. This type of bogus story will feed the municipal IT staff paranoia and make it impossible to get this kind of access in the future, regardless of safeguards.
You are correct, Ken. There are lots of things on a water and wastewater site more significant as potential targets than failing a pump! To access them would generally require several things simultaneously:
- Malicious intent
- Knowledge of the plant equipment
- Knowledge of the SCADA system
- Knowledge of the passwords and other IT protections
- Knowledge of the tag base, equipment register addresses, etc.
Could it be done? Yes. It would probably have to be an inside job, though.
Headline: "Hackers halt plant operations in 'watershed' cyberattack" ...
5,637
Last Wednesday night I watched Omni on PBS. It was a special about how hackers are now (or have been) hacking into networks and taking control of...
6,002
We are installing a PLC that is in gray area between commissioned and actively running. We have 2 log ins on the HMI, my log in and the client's...
665
I installed braking resistors on 15 identical drives over the last few weekends. After enabling them on one line using CCW, they worked fine. On...
3,206
"Failed to create module" Error when I hit "New Module" in Compactlogix L330ER Hi PLCs.net! I have the following error pop up on screen: Does...
2,029
