FactoryTalk ME: Logging who hit buttons
jakeparsons03
Jun 2017
Indiana
78
We are installing a PLC that is in gray area between commissioned and actively running. We have 2 log ins on the HMI, my log in and the client's log in. Our fear is that something goes down or stops working and the client looks at us thinking we broke it when one of their guys hit the wrong button.
I assume there is a log of every button pressed and tied to the log in name. Does anyone know how to access it?
I have not used FT ME in a while (just SE), but I believe that logging button presses is down to the developer.
In SE, I normally use the 'Remark' command to send a comment to the events file (Alarm and Events SQL database).
An alternative if ME doesn't do this is to have the button generate an alarm and then you can log the alarm (have it non-latching, not need to be acknowledged) and then have a 1 sec timer to unlatch the alarm so that it can be triggered again next time the button is pressed.
If you have alot of buttons, its alot of alarms to be generated.
Others might have better solutions.. best thing about this forum is all the different solutions to problems
Hi All, I'm trying to look into if it's possible to get FactoryTalk SE to build a process log report, recording various tag values at a poll rate...
578
I am having an issue with Factorytalk View SE. I am trying to add new alarms which is requiring me to use the "AlarmOff" command in the command...
629
Hey guys how would you approach the spreadsheet screen part? I searched and everyone points out that using parameters to display this information...
750
Hi, Is there a way to do data logging to an Access database on a PLC tag turning from 0 to 1? I know how to do data logging using FT view but...
945
Hi. I have a strange issue with Points added to the Historian where they update for 1 minute and then stop updating for a period and then start...
1,368
