Hart 1756-IF8H vs 1756SC-IF8H
Where did you get the 1756SC part number from? The 1756 is just the ControlLogix family designation.
The -SC suffix means it was manufactured by Spectrum Controls - sorry to say I can't answer your question though.
It seems 1756SC-IF8H is obsolote, it looks like spectrum controls doesn't supply it anymore since rockwell came out with the 1756-IF8H model.
I´ve been using the 1756SC-IF8H for several years now, never use the one from AB, but a guy from SC told me the other day that they are basically the same but the one from AB has a template designed by AB that makes things easier and you do not have to configure every bit manually like in the past.
RA Answer ID # 46614
The modules are still built by Spectrum Controls, but the ones with the A-B part number are sold and supported by Rockwell Automation. The module profiles and firmware support are built into RSLogix 5000 v16 and later.
Anyone have experience using this module they can share? I like the idea of retrieving more data from an input channel than the one being read by...
2,407
Hi guys, Lately I was involved into a project utilizing 1756-IF8H HART analog modules. Standard features described in module manual include only...
6,526
Hi, I do have a job where I have to connect 13 Transmitters to an Allen Bradley 1756-IF16IH, 4-20mA directly as Mass Flow Range. I also need to...
3,561
Hello All, I am looking for a way to add charts to my web pages to display data. I was looking at using Google Chart API but I can not add the lib...
1,790
I am trying to write a script for a 1756 eweb to chart downtime with a time stamp, I am trying to log daily downtime on a power chain. I need the...
3,987
