Has anyone added a 1771-OFE2 to a SLC over RIO
lunenburger
Jul 2008
Summerside
209
Hey there, I have a SLC5/05 in a 13 slot rack with a 1747-SN RIO Scanner.
The scanner is connected to a PLC5 remote rack.
I have to put a 1771-OFE2 analog output card to the PLC5 remote rack.
I assume the block transfer will be similar to setting it up in a purely PLC5 rack...
Has anyone tackled this before? any tips?
Yes I have done this recently. As you have assumed it Is very similar to the PLC 5 block transfers. The only difference is using M data files for BRW & BTR. I used the 1747-SN RIO manual which has examples for the 1771-ASB setup. Then used the modules ( in my case 1771-IFE analog input ) manual for word count and control block length. If you have more questions or issues let us know and I can post the file or give you any other information I had from when I set mine up. Good luck.
Apparently, they are not compatible and i was hoping there was a work around.
692
I've been getting some advertising related to the attractively packaged Wago Compact Controller, model CC100, lately. As far as I can tell it's a...
2,221
At our facility we have some strange behavior from one of our ControlLogix PLCs. It runs three palletizers. We have had some rare but very...
1,596
Hi all, I have a client that has a water tank with a loop powered level sensor; the 4-20mA loop goes through a telephone line, half a mile away...
26
6,987
I'm working on a temperature/humidity test chamber that was made in China sporting a TATO PLC that looks exactly like a Micrologix 1000. Also has...
3,286
