At 135 feet, it's really a 'star' configuration and not a dropline. The signal at that distance is going to depend on the loading from the rest of the network daisy-chain.
I do not expect it to work reliably.
Once you've thrown out the basic principles of the network, you may as well treat it like an engineering project. Connect a scope to the junction where you're going to add the 'dropline', and get a look at the signal quality there. Then add the new network leg and take a look at the signal waveform at the extreme end. Try without a resistor, and with a 60 ohm resistor, and with an 82 ohm resistor, and with a 150 ohm resistor. This is tricky because you're never sure which node's data you are seeing on the scope, and for the network to function properly each device must see valid data no matter where it is located on the network.
I have seen installations like this, where a 'dropline' was run 50 to 80 feet to a PLC or PanelView that was added to the network, that worked marginally for years.
They were able to improve those installations with a Weed Instruments (owned by Ultra Electronics) EOTec 2000 repeater.
These devices are built to be fiber-optic repeaters but can be connected with their copper modules only to be a DH+ 'hub'. The 2C12 model can give you a nice clean DH+ signal that you can run for another 10,000 feet.
