jrexrode
I'm looking for a device that I'm not sure is or ever has been mass produced. If anyone knows of such a thing, or anything like it, would you let me know.
Ideally, it is a device that you can set an address on using 2 BCD switches. This address would then be sent out as a pulse stream. So, let's say the address is 25, then maybe there would be two pulses follwed by a pause, then followed by five pulses followed by a longer pause than the first, then the sequence starts over.
The purpose for this I have in mind is for tooling identification, so that instead of using multiple inputs for identification, I can use a single input. I've searched and can find circuits where the pulse rate is based off resistance value, but I haven't find one based off BCD switches, which I would think would be more involved than potentiometers. I'm hoping there is an off the shelf solution.
