having trouble connecting step7 to s7-200
matgyver
Jan 2009
irvine
I’m trying to connect to a S7-200 plc with a pc running STEP7-MICRO/WIN v4.0.0.81 and a PPI to USB cable. This connection worked fine before. But now after the last download (and a few days) the connection will not work. I tried connecting to different ports on either side (pc and PLC). I Even tried a different computer and fresh software. If anyone has any idea what could have change or if there is a way to reset the plc back to factory settings. It would be greatly appreciated
Matt
Taking the 'after the last download' as a place to start, you may have set the port speed to a new value. Make sure you select the 'try all speeds' option on the download page. If that doesn't fix it we need to know what settings you are using as you try to download and maybe some screen shots. You may also want to download the latest version of the software.
Bryan
This might sound obvious, but check the dil switch settings on the ppi adaptor. Could they have been knocked or has a colleague been "Helpfully" setting them for you!!??
Are you using your port for some special job?
There are many fuctions like USS protocol where your port is set as free port,in that case you can not communicate to PLC in the run mode since those blocks are being executed,you can switch the plc in stop and then try out.
Baud rate can not be a problem as it supports the maximum supported for S7-200,there are even no dip switches.
Try another cable.
If you are sure about the baud rate then try out cable with com port.
i have faced many problems in usb cable like showing some errors while going online,online editing broken.....etc.
you can reset your plc to factory settings.
get an S7-200 EPROM,copy empty program block,data block and default system block(9.6 baud rate) from another PLC to the EPROM and plug it in your plc.
give a power cycle
Now your PLC has what you had in the EPROM.
Hello guys, One of the very few compact logix PLC's on site has an NFG analog input channel. I need to get online with the processor and change...
3,704
Hi, I am new and barely know what I am doing and I have some questions. I have a Direct Logic DL06 PLC with DirectSoft 5. I at one time had...
8,378
I am new to this software so I will explain the best I can. I am helping a user migrate from an old XP machine to Windows 7 Ultimate 64 bit...
1,197
I can connect through the serial though... I got the IP address for the processor ( 100.100.100.1 ), but I still can't get connected... I'm using...
5,502
Hey guys, I worked on this all night last night and all afternoon today. I have a SLC5/04 that I am trying to make a msg read from a PLC 5/20. I...
2,230
