The Setpoint is your desired value. In other words, if you are trying to control temperature, and you want the temperature to be 100 degrees, then your setpoint is 100
The Setpoint is the value you want the process to be at. (What you want)
The Process Variable is the value that the process is at. (What you got)
PID determines the difference between what you have and what you want (the error) and changes the controller's output to attempt to get the what you have to match or equal what you got.
I want to control the temperature, so the PV is my thermocouple reading and image its like 1400ºC and I want 1300ºC.
I put 1300ºC on the RSP and it changes the fan velocity to stay at 1300ºC ?
I do realize that the path to comprehension Google Fu is difficult and thorny, and not everyone can go through it. But try it anyway. Check what will be in the first link to the "Hc900 pid" request
