HC900 Revision 7.2 Error
_V_
Aug 2023
Portugal
31
Hello everyone,
My designer software as the 7.200 firmware, but when I go to download to the plc HC900 from honeywell the program I created appears an error.
" Download Aborted : Configuration does not match controller type or revision "
And when I put the program in firmware ("revision") 6.2 it works.
Any ideias on how I can put the HC900 with revision 7.2 ?
Here are some printscreens.
https://ibb.co/v11FSZr
https://ibb.co/54cp33B
I'm upgrading an existing machine with a Honeywell HC900 controller, and I'm trying to do some data processing in the controller. I have variables...
56
Hello everyone, In the designer softwar of the plc HC900, I used the function version control on the toolbar and it deleted files from my...
355
Hey Guys, I am getting random rack/slot errors. I go to download and everything is ok but then it has a error. For example - Yesterday everything...
369
Hello Guys, I'm working on Honeywell HC900. I am using the PID block. I have attached the Switch and loop block to it as well. I have attached a...
634
Hello everyone ! I read the help tab on the PID function block but I dind't understand. Can someone explain to me ? And how to use setpoints ?
817
