HC900 Version Compatibility
archy
Jul 2014
California
52
I was given a C30 to develop a program on my test bench and a 10" Control Station for the interface. When I arrived at the jobsite, I discovered that a C30S had been installed along with a 15" Display. The cde and sds I had created are not compatible with these devices. The Hybrid Control Designer software I have doesn't have a C30S Save As. Am I out of luck or can these files be converted for use in the installed devices?
What is a C30S? Where does the number come from?
The only suffix letter I'm aware of is the C70R, the redundant controller.
There's a scanner module for additional racks, but a scanner only works with C50, C70, or C70R controllers; and a scanner is not a CPU, it's an I/O scanner.
Honeywell just recently came up with a whole new set of updated hardware for the HC900 family. The C30S is one of them and as archy pointed out, it's a SIL rated processor.
You will need to update your Designer Software to version 6 since in order to be able to convert your current project to a C30S. That's the version I'm using right now, and I have the option to Save As "HC900-C30S Rev 6.0x files (*.cde)"
I'm assuming there is an update for the Station Designer software too, but I haven't seen that one.
Dear Buddies, I'm new to Honeywell product, So I start with some basic question: I downloaded the demo version of designer software from...
2,163
I'm upgrading an existing machine with a Honeywell HC900 controller, and I'm trying to do some data processing in the controller. I have variables...
71
Hello everyone, My designer software as the 7.200 firmware, but when I go to download to the plc HC900 from honeywell the program I created...
671
Hello everyone, In the designer softwar of the plc HC900, I used the function version control on the toolbar and it deleted files from my...
361
Hey Guys, I am getting random rack/slot errors. I go to download and everything is ok but then it has a error. For example - Yesterday everything...
375
