Heartbeat Failure Barber Coleman Maco Rs
Aug 2021
Nashville
Hi hello. I’ve invested tons of time and money into retrofitting an old blowmolding machine to run plastic fuel tanks/Jerry cans. My machine is a 2004 Bekum BM506 and it has 7 extruders. We initially had lots of drive errors in communications but have cleaned up all cable framing errors etc that we seem to be told by the STAT diagnostics.
We continue having a PLC4 heartbeat failure which kicks the machine to a status called “time slot not running”. It’s really become a burden with all the downtime and poor troubleshooting.
If anyone thinks they could help…
Bump on Barber COlman MACO help
Hey just been running this machine for nearly 9 days straight and suddenly a data handler 4 heartbeat failure and my on-screen software (wonderware) tells me the time slot is not running..
When I go out on my network (ModbusPlus) I notice the same Node is always missing. Address 4.
DRIVING ME CRAZYYYYYY
Do you know what device has Address 4?
ModbusPlus uses 2 wires plus ground, generally crimped into sub-D style connectors. We had issues with corrosion on those pins within the connector. Cleaned up with contact cleaner and re-seated the wires every now and then no more issues.
Since it is a daisy chained network, I'd check the connectors on the devices before and after device 4.
Hi everyone, I have a task at work that I'm hoping someone will be able to help me find a solution for. Here is the background info: I have a...
457
Hi everyone I've created an FC that includes the blocks TCON, TDISCON, TSEND and TRCV. This block has to be as generic as possible across...
1,622
In studio 5000 is there an easy way to do a Heartbeat between two Control Logix PLCs? Say you have Produced and Consumed from both is there even a...
1,249
Hi all, I have an application where there is a Control Logix PLC connecting to a B&R remote I/O station over Modbus TCP via a prosoft MNETC...
1,929
Good Morning! I need to monitor ethernet comms, between 2 Compact Logix PLC's. I have done this before with a simple pair of timers, toggling a...
1,617
