Heat Trace
sjknight
Nov 2005
St. John's
Does Anyone Know Anything About Running Heat Trace. I Heard That You Have To Use A Conduit Bender Because It Is A Mineral Insulated Cable. Thanks For Your Help.
Link below is to Nelson's mineral insulated installation and maintainence guide.
The book doesn't mention a bender.
Mineral inulated is about 1/4" diameter, which in long lengths can be bent in large radius by hand.
There are benders used for small diameter tubing, but I don't recall mention of these by the installers. Maybe it never came up?
Dan
Not sure what product you are referring to. I have used a flexible Ni-Chrome wire since the 70's, not sure on the brand as it is stocked in-house. ~0.5 ohm/ft, measure off 55', add a 5 Amp fuse and plug it into 110VAC. Add a thermostat if required/ desired depending on the application. There are various vendors I have seen that make specilized products with built in thermostats (e.g. water line freeze protection). I believe RayChem has a large presence in this market and cater to the chemical industry from the literature I have seen, though that was a number of years ago.
Will check on our vendor information next time I'm on the floor.
I've done a few deisgns incorporating Heat Trace. Check out this website: www.briskheat.com. They have a lot of examples of how their heat trace tape and wire operate and how to correctly size the wire and wraps needed for a design.
What type of application is this? Most heat-trace cabling is very similar to Romex-type wire, and is fairly flexible.
A major problem with using electical tracing is that the temperature is absolutely NOT constant;... If you need to maintain a constant temperature over a line, it's best to go the (very expensive) route of using a liquid-jacketed system.
Hi, I’m a new member and I have a question about the PID function in a Micrologix 1400. I have 4 separate Heat Trace circuits that I need to...
3,789
I am working on a system mounted outdoors in a cold climate. I need some flexible tubing, about 3/8" ID, for air less than 1 psi above...
1,895
Hello all! I am fairly new to the world of PLC's and this forum, so I apologize for my lack of knowledge. I have a Powerflex 753 that keeps...
581
Hey All, I've got a Vacon x4 VFD running in open-vector mode. It is spinning a heavy pin-mill wheel. It gets frequency reference from a PID...
20
2,558
Hi Can someone please tell me where I can find information about the heat developent / dissipation of a Simoreg DC Master? 📚 The information...
943
