Tom Jenkins
I am working on a system mounted outdoors in a cold climate. I need some flexible tubing, about 3/8" ID, for air less than 1 psi above atmospheric. The air is moist and frost is possible.
I can put heat trace tape on standard tubing, of course. However, I think I have seen instrument tubing with built in heat trace tape. I've searched the web a little, and found stuff that would work, but the configuration isn't as clean as the item I think I remember.
Any suggestions?
Any suggestions?
