Heating Element Thyristor Control
Thyristor Control Mode
  • Full Wave Logic On/Off
    Votes: 0 0.0%
  • Full Wave Fix Cycle
    Votes: 0 0.0%
  • Full Wave Variable Cycle
    Votes: 0 0.0%
  • Half Wave
    Votes: 0 0.0%
  • U a Open Loop Control
    Votes: 0 0.0%
  • U*U a Open Loop Control
    Votes: 0 0.0%
  • I a Control
    Votes: 0 0.0%
  • I*I a Control
    Votes: 0 0.0%
  • U a Control
    Votes: 0 0.0%
  • U*U a Control
    Votes: 0 0.0%
  • Leg External Ref 23.65
    Votes: 0 0.0%
  • Total voters
boneless
Feb 2008
OKC
1,628
Hi all!
Hope everyone is staying safe and healthy.
I am (still) working on a program, involving thyristor control of a heating element. Seems I finally have things working alright.
I do have one question, do you guys have any recommendation for control mode? The ABB DCT880 offers the options in the poll (U*U = U squared, a = alpha), and they seem to recommend full wave fixed/variable cycle. But to me it seems that would be identical to using PWM with a couple of SSR's. What would be the advantage of using the thyristor?
Any recommendations?
Depends on the heating element and system configuration. For example if you are using low voltage to the elements via a transformer in order to get high current, then you can't use the variable cycle method at all, you must use Phase Angle control. No idea however just how that translates to the terms they are using, most of those are not industry standard terminologies that I have ever seen.
Thanks.
They are regular steel immersion heater elements. Nothing special about them or the supply.
Power is supplied directly, no trafos. 400 VAC to first and 690 VAC to other. Appropriate sized elements for those voltages.
The names of the control modes are taken directly from the abb manual.
The heating element is enclosed in a steel sheath, probably a stainless steel sheath. Most likely the heating element is nichrome wire.
Nichrome - can handle any control mode.
Which mode works best depends process conditions like where the sensor is and how well it represents the needed temperature and how well the heat is transferred to the medium.
The plastics industry uses lots of plain old time proportional control with SS heater cartridges driven by a plain old SSR (zero cross, not phase angle fired).
I suspect that "full wave, fixed cycle" is the same as time proportional. If ABB has the terms, they also have a description somewhere, probably with a diagram.
Hello PLCs.Net! We have 3 elements in a star configuration, and each of the elements are rated for 20kW 120V - This is all I know about the...
1,279
Hi all! Helping a co-worker out with a home brewing setup. He wants an accurate temperature control, so we have divided up the element in two...
4,431
I have a few tanks that each have 6 heating elements. I'm trying to figure out the best way to control them.. 1, They each have a contactor in...
35
8,545
Did anyone please help me with gsd file of krones heating module(make Siemens)
91
101
