help a protool beginer
Escumalha69
Mar 2008
Portugal
Hello i'm a protool beginer and i have to make a school work.
the work consist in make the game BATAK, the program in plc is done, and i have to interact the protool with the plc.
i want to know how save the score of the game into a file, the score is number in a counter ("c54")and associate the score at one name.
Basicle i whant to know how i save the name of the player and associate it to a number of the counter.
can someone help me??
Hi mate,
You can't really "store" information like that in a HMI. You need to use the PLC to store the information (in your case the players name and score). Then you use the HMI to display the information.
In your case I would set up a button on the HMI (although you don't say which HMI you are using) that will initiate the 'save'. This button would pass the players name and score into a datablock to be saved.
You could also have a "high score" datablock with a bit of extra code...
All the HMI does is provide a 'window' into the PLC so don't get confused into thinking that the HMI does any clever processing...
Hope that helps a bit...
uptown47 said:
Hi mate,
My PLC is siemens i use s7-200 and the software is SIMATIC PROTOOL
uptown47 said:
That's fine. But, as I mentioned, you really need to be storing the information (ie. player, score etc) in the PLC as oppose to in the Human Machine Interface (i.e the OP7 or touchscreen etc)
i really need store the information in a file and i use a PC not a OP7 or touchscreen the protool RT runs in a computer.
Look at functions available in Protool scripting, 5-6 years ago I had the same physical setup and I was storing and retrieving small amounts of data to the hard drive. I remember I had to write a script but thats all I can recall.
i finished a new project by protool v.6 sp3 on win xp , i have S5 TTY Programming Cable when i connect to op 15 display transfer ready but when...
1,285
This is a different problem but on the same machine as my other post. Basically there is an alarm message showing up on the TP270 HMI, and I am...
6,626
Hello I have a problem when I try to convert a protool project in wincc flexible. I receive the next error: 14:44:44.78 General Error ...
2,290
Hi, I need to switch two MP270B Protool projects over to WinCC Flexible. I'm going to do this late tonight and i...
4,273
HELLO I have a problem with an old protool file xxxx.o15. The problem is that i dont have such an old program to open this file, i need protool...
2,200
