No. The code was added offline, then downloaded. I've just re-downloaded again, and still have the problem. One thing I'm not sure about...
In RsLogix 5's IO configuration screen, I've got "Chassis_2" config. fields set as follows:
I/O channel: "1B - <I/O Scanner>"
Chassis Type: "1771-A3B (12 slots)"
Adapter: "1771-ASB Series B"
Inh: not checked
Res: not checked
Rack Addressing: "1 slot"
Rack: "3"
Group: "0"
Span: "3/0 - 4/3"
Complementary: "NO"
Now, I originally did not have a "Chassis Type". Instead, under Channel Configuration, I did an Autoconfigure, which added the following to the Channel 1B listing:
Rack: 3
Group: 0
Range: 030-037
Since the 3rd rack is RIO'd via a 1771-ASB, and since the AutoConfig added the 3rd rack to the list, I didn't have a second A3B chassis added to the IO Configuration table. So I added another chassis to the same line that contains the I/O Channel "1B - <I/O Scanner>" in the I/O configuration Chassis Table.
It's not clear that this is necessary, but if I DON'T add the chassis, I do not get the Chassis configuration screens that allows me to define what modules go in which slots.
I'm still not sure about this one. In any case, it doesn't seem to make a difference. I simply cannot make outputs in rack 3 "active".
Thanks,
Jim
