Help does DH+ directly pass thru ch1a to ch2a on plc 5
not4u2c
Feb 2009
sc
I have a plc 5/40 connecting with data highway connected to both channels 1a and 2a. When on one channel, with laptop, I only see what is connected on the highway to that channel only. Shouldn't I see everything on both sides of data highway if I'm using both channels?
I would have thought so,
But, thinking about it more, they are clearly separate networks, that can be comprised of up to 128 nodes, with 2 separate networks of 64 nodes.
Electrically, the connections are separated from what I understand.
Good question, maybe Ken can let us all know for sure.
I have never run into that many devices on 2 networks before to see this....
DH+ networks can be linked together because the DH+ protocol allows for a Link ID as well as a Node ID. This is how the Gateway functions of the PLC-5/250 and ControlLogix 1756-DHRIO work.
But the PLC-5 has no channel-to-channel "passthrough" or linking features. When you are connected to Channel 1A, you only get access to the devices on Channel 1A, and likewise the other channels.
A lot of users are so accustomed to the linking and browsing the ControlLogix provides that we forget the PLC-5 didn't do these things.
Any help for a Beckhoff PLC that does not start up correctly the first time? The system will lock up, stop responding at times, requiring me to...
1,785
Hello Gurus, I have started teaching myself Allen Bradley PLC with RSLgoix 500 and LogixPro with grateful and helping comments of you gurus...
3,998
Ok, my parents own a dry cleaner and the main machine broke. THey said we need to replace the main PLC, which is a Mitsubishi Melsec FX2N-64MR...
3,611
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
86
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
22
458
